Parked for 9 months, put in new batteries and it wont start?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-26-2014, 06:49 PM Thread Starter
I have a 2001 F250 7.3 that has always run great. I parked it for 9 months, both batteries died over that time. I installed 2 new batteries today, when I first turned it over it tried to start a few times, now it just turns over and doesn't try to start. Weather was about 60 degrees outside.
I installed a new fuel filter (just in case) and that didn't help.
The "Wait to start" light is working, it is pumping fuel (I checked when I changed filter).
I put a battery charger on the New batteries about 2 hours ago. Though it turns over good I thought it could be the problem?
What could the problem be?
Thanks
2001 Ford F250 7.3L Diesel
patcherman is offline
post #2 of 9 Old 01-26-2014, 06:55 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Could be CPS, bad fuel, bad oil.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 9 Old 01-28-2014, 11:50 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
hpop could be dry.
pull the top plug and see if its empty, if so fill it up about an inch from the top then try it.
also try changing the fuel filter and adding some additive in the tank.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 9 Old 02-01-2014, 08:12 PM
Quoted: 14 Post(s)
If you open the fuel bowl drain valve, does anything come out? If not, could be the upstream pump, or plugged fuel filter.
ttyR2 is offline
post #5 of 9 Old 02-05-2014, 06:23 PM
VallejoVillain's Avatar
Air in the system?
VallejoVillain is offline
post #6 of 9 Old 02-12-2014, 07:17 PM
7.3 no power
hi i have a 1999 ford f 250 7.3 new batterys i drove it to work today i go on my lunch break and open my door no power at all completely dead could it be the starter or the alternator any suggustion
7.3 smith is offline
post #7 of 9 Old 02-12-2014, 07:51 PM
Check Battery terminals
Transmission not set to Park or Neutral
Busted wires in starting Circuit
Starter Jammed
If it's not one of those easy things...could be something worse. Good Luck
post #8 of 9 Old 02-12-2014, 07:52 PM
Or short circuit causing drain on the battery (batteries)
post #9 of 9 Old 02-13-2014, 06:16 AM
jesilvas's Avatar
Quoted: 2 Post(s)
No power as in no lights anywhere?
If so, start at the batteries, and work your way down the wires.
4R100, 2wd
330,000 + miles
jesilvas is offline
