Truck not runing right! PLZ help! - Ford Powerstroke Diesel Forum
Old 10-11-2008, 05:53 PM
So im sorry for posting cause the problems always sound the same but i need feeback.
stock early 99
manual
heres how it went down so i start my truck and i am going to get fuel and to another store with some friends. We get about a mile away from the drive way and i start to loose power so i pull over and shut it off. I go to turn it back on and it starts but it just knocks something horriable. Immiatly i think CPS but anyway so we got a can and put fuel in the truck to see if that was the problem and it was not. so if you start it it almost sounds even worse. so i get it back to my driveway and we replace the CPS and now the truck will crank and kinda start but it sounds even worse that before.
Any suggestions?????
Please help I need to get this fixed because this truck is my only way home from college.
Thank you for your time
Old 10-11-2008, 05:56 PM
is it a rod knock or a missing knock. is it very low on power.
Old 10-11-2008, 06:11 PM
well from i can tell i think it is a missing knock it just runs like total crap if it even starts
Old 10-11-2008, 06:13 PM
Cynic
when was the last time you changed the fuel filter?
Old 10-11-2008, 06:19 PM
i replaced the fuel filter in july and i only put about 2k miles on it
Old 10-11-2008, 06:28 PM
Cynic
If you turn the key on, you should hear the fuel pump under the cab.
On the back of the fuel bowl, you should see a yellow lever. Have someone turn the key to the on position while you open the yellow lever. Fuel should come out under the truck under high pressure.
Old 10-11-2008, 06:36 PM
how high is high i just did it and it would come out but not like a jet or anything
Old 10-11-2008, 06:39 PM
Cynic
It won't be a jet, but it should be under pressure when you open it up if the key is turned on. You really need to get a good scanner on the truck.
Old 10-11-2008, 06:42 PM
yea it was flowing out. i might be able to get it to a shop, well it is a diesel school but its good enough.
Old 10-11-2008, 06:48 PM
Cynic
low fuel volume/pressure can cause a knocking sound. But without seeing the data stream, I'm guessing.
