Oil leak in front of engine - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-23-2014, 02:44 PM Thread Starter
r_marczak_83's Avatar
Every time I drive and let truck sit, there is an oil spot about 8" around. There is also oil all over the front diff cover. There is no oil around front hpop cover or around there. Where can this be coming from then
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 10 Old 01-23-2014, 04:40 PM
schlutzer's Avatar
Quoted: 18 Post(s)
If its oil, my bet is the front side of the oil cooler, it will leak all over the axle.
If its red, its something from your power steering system, likely the steering box
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 10 Old 01-24-2014, 07:19 AM Thread Starter
Its black engine oil. You could be right on it being the oil cooler, as I recall seeing it have small traces of oil on it last summer.
Ill have to look better (of course when its warmer out )
E99 F250 ex-cab 7.3
post #4 of 10 Old 01-26-2014, 07:08 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
i second the oil cooler, maybe check the inspection port for the hpop behind the ebpv tube?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 10 Old 02-26-2014, 03:24 PM Thread Starter
It leaks like a siv when its cold and I first start it. Today at work it was actually dripping from where ever. Then once warm, it quit. I am leaning towards oil cooler also, but need to look while its leaking.
E99 F250 ex-cab 7.3
post #6 of 10 Old 02-26-2014, 03:26 PM
Quit trying to figure out what it is....it's the oil cooler leaking. You don't need to look while it's leaking, the most common symptom is leaking on a cold start and stopping when oil temp comes up.
Get the oil cooler seals and fix it.
Dan V is offline
post #7 of 10 Old 02-26-2014, 04:34 PM Thread Starter
Ordered them now. Thanks
E99 F250 ex-cab 7.3
post #8 of 10 Old 02-26-2014, 04:39 PM
check around the front part of the oil pan.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #9 of 10 Old 02-26-2014, 04:43 PM Thread Starter
I havent looked real hard, but when I did today it seemed like it was higher than the oil pan.
E99 F250 ex-cab 7.3
post #10 of 10 Old 02-27-2014, 08:04 AM
Step 1. Douche it off
Step 2. Run engine find leak
Step 3. Order parts
Step 4. Fix leak
Step 5. Drink beer/plow the old lady
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
