Hpop gear cover leak - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-21-2014, 03:28 PM Thread Starter
kbragg430's Avatar
So i have a small oil leak coming from the seal around my hpop gear access cover that holds the ebp tube and sensor.
Do i need to drain the hpop reservoir before removal? It only leaks while runnig and i saw a vid of a guy actually running his 7.3 with the cover off and showed the gear slinging oul around, however it did not appear to be a fluid filled chamber of sorts. Is this the case? Can i just remove and reseal?
Thanks
Kevin
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #2 of 2 Old 01-21-2014, 11:51 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
honestly you gotta remove it to reseal it anyways.
so its gonna leak out whatevers there, once its done leaking out reseal it.
you can refill the hpop by removing the bolt on top.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
