i have a 99 350 always runs good parked it 3 days ago and when i went to start today i turned key to on noticed the off light was on on shifter and also noticed the glow plug light didn't come on truck just spins over but won't start temp was around 42 deg anybody know what to check first? is there a fuse or did the glo relay die? thank you:
does anyone have any suggestions?
Did the wait to start light come on? Mine did the same thing, had a bad relay for the for the wait to start system. Switched it with another relay and it started. If you have the owners manual look where the relays are and mark them before switching them, if it starts then you can replace the bad one.
the fuse for the wait to start lamp is #19 in the interior fuse block. it also controls the overdrive cancel switch. but it also has most of the other dash lights on it. i agree with 460+ to check and make sure that your glow plugs are functioning properly. cause i believe it should still start if you wait approx the usual amount of time.
no wait to start light means no power to pcm, like said before there is a blown fuse , the fuel heater is probably causing your problem, unplug the heater and replace fuse , should start
thanks i'll be looking at it tomorrow never had any problems wait to start light does'nt come on but i do hear chime after a few seconds engine spins over but won't fire i'll start with fuses don't have owners man is the fuel heater on filter housing? thanks
unplug the white conector on the back sie of the filter housing
Yep, fuel heater, had the same problem. Unless you live in extreme cold climates, you dont need the heater anyhow.
ok i'm getting closer int fuse # 30 or #31 a 30a fuse was blown is this the pcm fuse or somehow related to fuel heater and is fuel heater plug next to drain valve? thanks
I think thats it. yep, fuel heater is connected too. White plug next to the drain, back side of the bowl.
