Sensor Problems - Ford Powerstroke Diesel Forum
Old 10-08-2008, 08:26 AM
PMR = JUNK
Sensor Problems
My truck started running strange the other day, it was idling rough and would surge while im driving down the road. I could keep the accelerator at the same spot and it would speed up and slow down. Then after a bit the SES light came on. I had it checked at auto zone and it was a P1107 i think. It showed low voltage in the MAP sensor. But i think the ICP is going out too, just not bad enough to throw a code. When it is running bad, i can unplug the ICP and it runs fine again. There is also some oil in the plug of the ICP.
Any thoughts? Can both of these be bought cheaper at an International dealer?
Old 10-08-2008, 08:50 AM
PMR = JUNK
Old 10-08-2008, 12:01 PM
PMR = JUNK
Old 10-09-2008, 04:57 AM
Sounds like a bad icp, i bought mine off Ebay for about $75 bucks. You might have to replace the wiring pigtail as well but i would try cleaning it out with simple green or something similar first and let it dry.
Old 10-09-2008, 05:30 AM
I just droped $140.00 International.
Old 10-09-2008, 04:52 PM
PMR = JUNK
A bad ICP would make the MAP throw a code?
Old 10-09-2008, 05:40 PM
Powerstroke Techie
it could if it is shorting the v-ref to ground. but usually it will cause a no start if that happens.
Old 10-09-2008, 05:44 PM
ADMIN AND TECH
sounds like icp sensor is your problem to me , replace sensor , clear codes and drive , see what comes back up
Old 10-12-2008, 08:12 AM
Where is the icp sensor???
Old 10-15-2008, 04:42 AM
Drivers side head toward the front, just behind where the fuel line enters.
