Motor Just...DIED - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-19-2014, 09:33 PM Thread Starter
Motor Just...DIED
Hey everyone, I have an issue, well my truck has the issue! I recently had my motor rebuilt, bored .30+, new heads, 230cc hybrid injectors, T-500 HPOP, a 6.0 inner cooler, and BD Triple Disc Converter. Had to get a tune from Jody at DP till I get live tuned in the near future. My issue is this, despite the slight turbo lag, three times now as I approached a stoplight, let off throttle and the truck "just died"! No blurbs, hiccups, shimmies or shakes, just quit, and I was still rolling. I put in neutral and she started right back up! Thankfully! Did not die again, until after I shut down for 1st time 45min or so, and then again this morning after sitting all night. I suspected CPS so I swapped that out, went for a ride and seemed like I had no power. I pulled over, loaded tune to stock, then reloaded my hybrid tune. Took off fine, 2miles later, died again, and re-fired with no issue since. I'm stumped. Any thoughts or suggestions?
jeffHstL7.3 is offline
post #2 of 3 Old 01-19-2014, 11:14 PM
kbragg430's Avatar
Check the nut on the ipr? I believe the t500 uses the same ipr setup. I may be wrong. But mine was doing that and it was because the ipr nut wasnt on and allowed it to move around.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
The Following User Says Thank You to kbragg430 For This Useful Post:
jeffHstL7.3 (01-20-2014)
post #3 of 3 Old 01-20-2014, 02:26 AM Thread Starter
Thanks KB, I will check that first thing
