Extremely hard cold start tons of smoke. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-18-2014, 08:55 PM Thread Starter
OHIO2002_7.3's Avatar
So I have a 2002 f250, extremely hard almost impossible to start in the cold. I've replaced everything I can think of. Here's the list:
Glow plugs, valve cover gaskets and wire harness's. Glow plug control module, my truck doesn't have the relay. I've replaced the ICP sensor and injectors aren't even a year old.
Hard starts at about 45 and if its plugged in it works as advertised.
OHIO2002_7.3 is offline
post #2 of 4 Old 01-19-2014, 08:16 PM
thetechie01's Avatar
Are you sure you don't have a relay? Mine had the same issue when the relay wasn't hooked up.. Replaced it with a stancor and fires like a dream
thetechie01 is offline
post #3 of 4 Old 01-19-2014, 08:35 PM Thread Starter
Yes I'm sure, its a California emmisions truck. So it has the Glow Plug Control Module instead. Identical to the 6.0 gpcm.
2002 7.3 crew cab long bed on 35's, stage two injectors 6 position chip. Waiting on a turbo.
post #4 of 4 Old 01-19-2014, 08:51 PM
Ah bummer, well that's all the info I have for you. Sorry, hopefully someone will come Lang with some better info for you!
