electrical help
I was driving in town today and my blinkkers stopped working. So when i got to the store i checked the fuse, it was fine. Then when i go to leave my abs light is on and my speedo dont work. I dont have a clue whats wrong cause all the fuses are good. Help please........Chad
two different circuits , doesnt make since , wiggle multi function switch and see if signals try and work, rear speend sensor may be your problem with speedo and abs light
like you said different systems doesnt make sense.
I just checked the bulbs and they are ok. Disconnected the batteries pulled the chip no change. Any suggestions?
ok just found out i have no brake lights and noticed the od light is flashing.
well the speedo fixed itself. found a bad relay and my fuse box had a loose connection. Shes good to go now!
jsut had mine fixed at dealer for same thing; speedo didn't work, abs light on and od light flashing. they changed"abs rear differantail speed sensor" $60 part and 1 hour labor
