Correct Adapter for a CLT-2 Cylinder Leakage Tester - Ford Powerstroke Diesel Forum
Old 10-03-2008, 12:48 PM
I need to replace my injectors and I want to do a compression test and a cylinder leakage test before I spend money on new injectors, but I only have the tools for gas engines. I already own a Star Products CLT-2 Cylinder Leakage Tester and I would like to get the adapters to use it on my 2002 7.3L PSD. Can anyone tell what I would need to use my CLT-2 Cylinder Leakage Tester?
I was planing on buying these to check compression. This type of adapter is the glow plug type.
Star Products
TU-15PB Diesel Compression Tester
TU-15-22A (Diesel Adapter - Direct Injection 7.3 Ford/Navistar Turbo)
Thanks for your help!
ADDED:I found a Diesel Adapter for a CLT-2 made by KASTAR #74460, will that work with a Star Products TU-15-22A adapter?
I was also going to order:
Ford Injector Remover / Installer OTC #6067
Quick Disconnect Tool for 7.3L Ford OTC #303-625
? Fuel Injector Sleeve Installer OTC #303-DS105
? Fuel Injector Sleeve Remover Set OTC 303-DS105
? Fuel Injector Sleeve Brush Set OTC 303-DS220
Ford Low Profile Fuel Filter Wrench #9030
Ford Dual Piston Caliper Retractor KASTAR #145
Any other special tools that I will need to service my 2002 Ford F350?
