Mixed AD & AE Injectors?? - Ford Powerstroke Diesel Forum
Old 10-02-2008, 04:35 PM
Hi all,
I have a 2002 F-350 4x4 SRW 7.3 PSD w/246,000 miles and no chip or programmer. I have the Auto Enginuity PC scan tool. I thought my problem was the harness under the valve covers. Well today when I pulled my drivers side valve cover I found that 3 of the injectors are AD and one is AE. Why would someone do this? Did someone try and swap a injector to see if it would fix the problem and it didn't?
When I do the cylinder contribution test I get codes P0272 & P0284. When I do the buzz test I get P1271, P1272, P1277, P1275 & some injectors sound loud and some are not. If I do need to buy new injectors will my old ones that are a mix of AE and AD work for the core charge?
Thanks!
Old 10-02-2008, 04:50 PM
duct tape & zip ties
This was done by the Factory.
I will guess and say the AE injector was in the 4th cylinder on the driverside. That cylinder in the firing order is number 8. With the new 7.3L's as in the 2002 the injector in the number 8 cylinder is an AE coded injector. It is suppose to help prevent injector cackle. Which also happens to be the injector that wears out first as I am told. Some believe it is because it is the last one to get oil. Some believe it is from being the last to get fuel.
I just had to replace this exact injector. I replaced it with an AD coded injector.
y truck runs a lot better now.
Now if you need to replace all injectors yes you can use the ae injector for your core. As most places realize that with the 7.3L there is one injector that is coded differently.
Old 10-02-2008, 06:22 PM
Thank you, I was really worried someone had been in the motor and screwed things up. I have been trying to read all I can about the PSD, but I didn't read that the #8 injector was a AE. I would like to DIY my injectors, but should I keep the 1 AE & 7 AD and rebuild them or buy 1 new AD and rebuild the other 7 AD?
So now that I have replaced the drivers side UVC harness and I still have the P1271-P1278 "cylinder #X high to low side open" codes that the IDM failed and needs to be replaced?
Also, I have replaced the CPS with a new one from Ford.
Old 10-02-2008, 06:41 PM
As for if your IDM is bad I am unsure of. I am sure a tech will be on here soon enough to provide you with that answer. As there maybe other tests that can be done to actually show if the idm is bad.
Old 10-02-2008, 07:08 PM
Just fyi the tecks are going to want to know what the origanal problem is. So post all info you have so they can help you.
Old 10-02-2008, 07:48 PM
The problem is the SES light will go on, but sometimes the light goes out. I just bought the truck at auction and when I looked at it the light was off, but when I won it and started driving home the SES light came on. It does look like some items were removed / wires cut, so I'm going to look under the dash and see if I see something wrong. I thought I got a good deal untill that dam SES light came on.
2002 Ford F350 4x4 SEW 7.3PSD, auto, 246,000 miles, STOCK as far as I know.
I get the following codes:
Enhanced Powertrain
P0603 Internal Control Modula Keep Alive Memory (KAM) Error
P1316 Injector Driver Module Codes Detected
KOER Cylinder Contribution
P0272 Cylinder 4 Injector Circuit Contribution / Balance Fault
P0284 Cylinder 8 Injector Circuit Contribution / Balance Fault
Buzz Test (during buzz test the #4 injector is very quiet compaired to the others)
P1271 Cylinder #1 High to Low Side Open
P1272 Cylinder #2 High to Low Side Open
P1277 Cylinder #7 High to Low Side Open
P1275 Cylinder #5 High to Low Side Open
Right now I want to get the SES light off so I can do some of the mods I've been reading about.
Old 10-02-2008, 07:55 PM
Cynic
The AE was for fuel reasons. The number 8 cylinder fires right behind number 6. Since the stock fuel system is a "dead head" design, there is less fuel available when number 8 fires. The AE injector compensates for this.
If you have good compression, it's time to replace all 8 injectors with AD's.
Old 10-15-2008, 12:50 PM
If you can lay the truck up pull all eight injectors and send them off to have torn down, inspected and flow tested. AD's are known for being out of spec and with that many miles will need some work.
