Scuffy, Dirk, HCH, & TWildman Check Here! - Ford Powerstroke Diesel Forum
Old 09-26-2008, 06:15 PM
The Screwy HEUI
Well, guys, I know you were racking your brains to help me get Heavy running again, & I got her back today. The BIG problem that was causing the no-start was the IDM itself. They had hooked up a 'test IDM' to the truck & it ran, but was skipping like crazy. After some testing, they found that cylinders #2 & #7 were weak. The problem was coming from the IDM harnesses(like you all had mentioned!). They installed the clips that someone else had mentioned on that thread, & it ran like a champ! Tony, as far as that hard shifting I had PM'd you about: I think this whole IDM problem was the cause. I haven't given it a good test yet, but when I drove it back from Ford, there was no hard or early shifting. I'll PM you info if I do end up having a problem, but I think the injectors being weak was possibly the problem. Thanks to all of you for going through the trouble & giving me a hand!
Old 09-26-2008, 06:54 PM
Cynic
No worries.
Old 09-28-2008, 10:46 AM
Powerstroke Junkie
Glad you got it done, but I am NCH not HCH, no worries lol!!!! I replied to your other thread, but man you got SCREWED BIGTIME!!!! Even with the harness anc clips you are well under a grand, even using the most expensive shop rate I have seen at $135 per hour. This is one of the dealers that was probably charging folks $400 for changing a CPS a couple years ago, heard about plenty of those!! Seriously, the next time you have $800 to donate I will send you my address!! Enjoy your flag!!
NCH
Old 09-28-2008, 11:05 AM
glad you got it running again
Old 10-23-2008, 05:32 PM
ADMIN AND TECH
i just saw this , good deal
