need some help with dtc's - Ford Powerstroke Diesel Forum
Old 09-25-2008, 08:37 AM
Question need some help with dtc's
i scaned my truck the other day because it just dont have the power it used to have and has a slight miss at idel...these are the codes i got
p1876- transfer case 2 wheel drive solenoid circuit failure
p0605 internal control module only memory (rom) error
i also did the contribution test and #8 had a value of like 5.XX %
and #3 was 2.XX % the rest were 0 or .1 % i dont know what the numbers mean. thanks for any help
Old 09-25-2008, 11:48 AM
ANY ONE? I DID THE BUZZ TEST ON A WARM MOTOR, IT CAME BACK FINE, COULD I STILL HAVE A BAD INJECTOR?
Old 09-26-2008, 05:05 AM
HUMM I GUESS I DONT HAVE HIGH ENOUGH POSTS TO GET HELP?
Old 09-26-2008, 05:38 AM
<-Day Of Fail now SOLD
I noticed that DIRK is logged on, maybe he could help you.
Old 09-26-2008, 05:52 AM
Cynic
Sounds like an injector issue. What did you use to test with?
Need to run a compression test.
Old 09-26-2008, 06:33 AM
the Auto E program
Old 09-29-2008, 07:25 AM
i used the auto enginuty program...
