HELP please! 7.3 is sick - Ford Powerstroke Diesel Forum
post #1 of 22 Old 12-30-2013, 10:30 AM Thread Starter
7.3Powerhouse's Avatar
-I have a 2002 7.3 f-250 and lately it's been having rough starts also sounds like it's misfiring or injectors arnt getting power, and idles terrible and when you put it in a gear the sound is worse and the CEL will be on when it does all of this and it has little to no power and takes forever to get it up to speed and it's even stalled before while coming to a stop at a light. I was leaning towards the uvch but I checked them and they weren't loose. It also shakes at around 40 mph and will go away after you hit 50ish.
I just changed the oil and filter, fuel filter, cps(from ford), new batteries, alternator, ipc . Haven't been able to scan codes either.
Also it has, k&n intake, TS 6position chip(took off still didn't help),4in turbo back. replaced the alternator a couple of months ago, and power steering.
Thanks for any advice you can give, Brandon!
7.3Powerhouse is offline
post #2 of 22 Old 12-30-2013, 01:29 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
maybe somebody else will have some suggestions but really need an AE to read the codes.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 22 Old 12-30-2013, 01:35 PM Thread Starter
Yeah, I just tried a generic code reader and it didn't read any. Just don't have the funds for ae right now
post #4 of 22 Old 12-30-2013, 02:02 PM
Quoted: 17 Post(s)
i understand that. post up where you are located, maybe another member lives close enough to help you out
post #5 of 22 Old 12-30-2013, 02:17 PM
well with a cheap pyro aimed at individual exhaust runners might show which cyls are misfiring if its say constant at idle, if its not too heated up and skipping, a squirt bottle, use this to see if one runner seems cooler than its neighbors. It might help direct you
fast_st is offline
post #6 of 22 Old 12-30-2013, 02:27 PM Thread Starter
Alright I will check that out, thanks!
post #7 of 22 Old 12-31-2013, 03:00 AM
And good luck, we're all counting on you
fast_st is offline
post #8 of 22 Old 12-31-2013, 03:13 AM
Colin7.3's Avatar
Look into the scan gauge 2. Its $160 off Amazon or any of the vendors here. It can monitor the 7.3 ICP eot ipr% mat and others. Also it reads codes on our trucks. To me it was money well spent
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #9 of 22 Old 12-31-2013, 11:21 AM Thread Starter
That's definately cheaper! I'll look at it thanks!
post #10 of 22 Old 01-02-2014, 11:56 AM Thread Starter
We'll my dad ended up buying the ae software with next day air for a late Christmas present, should be here in the morning so I should be able to post codes to help diagnose!
