GPR not activating - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-29-2013, 03:49 PM Thread Starter
GPR not activating
2001 f350 7.3 with 350,000 miles. Vehicle in California. Recently noticed hard to start first thing in the morning. I have read through the forums and completed some testing. Glow plugs all test at 0.9 ohms. GPR does not activate when key is in the on position. I have tested the GPR by grounding it to the frame, turning key to on position and I can hear the relay activate and I also get a voltage reading on the second large post. Any suggestions on what to test next or how to remedy the problem. Thanks
Arrrgh! is offline
post #2 of 5 Old 12-29-2013, 03:56 PM
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
Do you have one of these?
-OR-
I ask because I own a CA truck and it has the module, not the relay. But there is a relay next to the module.
Where in CA do you live?
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 5 Old 12-29-2013, 04:03 PM Thread Starter
Actually I have both of those. Is there a way to test the controller? I live in Oceanside. Thanks for the quick response
Arrrgh! is offline
post #4 of 5 Old 01-04-2014, 03:41 PM Thread Starter
So am update. I have tested the GPR and it is good. I just installed a new GPR controller from Rockauto. All i get when i turn the key is "click." Where do i go from here?? Thanks
Arrrgh! is offline
post #5 of 5 Old 01-06-2014, 07:00 PM
when my oil temp senses above some temp (not sure exactly what temp), my gpr doesn't even come on. Is it possible that the sensor telling the circuitry when to come on and when to stay off is failed? If the logic is telling the GPR that it is not needed to start the engine, maybe that sensor needs replaced. Just an idea?
2000 F350 Crew Cab 7.3 liter 4x4 short bed, 6 pos w/PHP, 6637 filter, hutch, harpoon, 4" downpipe, 5" exhaust, ISSPRO gages, 305 series tires, stock suspension with level kit up front, '05 headlight mod.
2001 F250 ECSB 4x4 - sold
2001 F250 CCSB 2WD -sold
2002 F250 ECSB 4x4 lifted -sold
Mama's 2009 Expedition EL 4x4
biscayne is offline
