Gauges won't go off even with key in off position! - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 12-29-2013, 01:31 PM Thread Starter
I have a 2000 f250 7.3...I have a 4 pillar gauge setup and the bottom one will not shut off when key is in off position...I'm confused and can't figure it out. All fuses are good and there are no shorts and unhooked wires...
Sent from AutoGuide.com App
Wyattforshee is offline
post #2 of 15 Old 12-29-2013, 01:54 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Did you install the gauges yourself or were they installed when you got it?
wvrrcarknocker is offline
post #3 of 15 Old 12-29-2013, 02:43 PM Thread Starter
I installed them about a year ago.
post #4 of 15 Old 12-29-2013, 02:59 PM
Quoted: 2 Post(s)
Have they always done this or is this a new occurrence?
post #5 of 15 Old 12-29-2013, 03:07 PM Thread Starter
Never done this tell now. Also top 3 gauges remember their last color but the bottom one doesn't. I have color changing gauges..
post #6 of 15 Old 12-29-2013, 04:47 PM
7.3pwrstrke's Avatar
Lemme guess... Glowshift?
Mine wouldn't turn off either. I believe it's because of a short inside one of the gauges itself. This makes one of the constant wires touch one of the switched wires. I'm assuming you connected all the constants and all the switched wires from all the gauges together when you connected them. This in turn makes all of the switches act up.
Quick fix: Connect your constant wires to a switched source instead. (I left my switched source disconnected)
Longer fix that'll be the correct way to do it: Disconnect every gauge and test each gauge individually on a 12v source (battery) and see which one will turn on when you touch the ground wire to negative and constant wire to positive. (leaving the switched source unconnected)
If
Wyattforshee likes this.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #7 of 15 Old 12-29-2013, 04:48 PM
I just saw that only 1 gauge is staying on. Take it out and test it.
post #8 of 15 Old 12-29-2013, 05:17 PM Thread Starter
Yes They are glow shift. They have been go to me tell now lol! And Ok I finally got them to shut off after doin a little monkeying with the gauge that wouldn't shut off. But the gauge still doesn't remember it's last color. All the other gauges do....
post #9 of 15 Old 12-29-2013, 07:45 PM
Hmm. I'd say to check it's constant power source. That should be what lets the gauge remember its color.
post #10 of 15 Old 12-29-2013, 07:48 PM Thread Starter
It has a good constant I think. Ik It is on all the time but what minimum voltage would U think it should be to keep its mem?
