99 F350 dually..wheel bearing help!!!fast - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-29-2013, 08:28 AM Thread Starter
Im in the process of changing the wheel bearing and the U joint on the short shaft on the drivers side..This is a early 99 F350 super duty dually..4x4 xlt. I cant get the axle shaft out..what is that seal?? and how do i get it out?? and what seal do i need to find to replace..I have looked these up and i am not sure witch one i need..On oreilly auto parts website..
Please help.
Name:	bearing seal 1.jpg
ID:	219474   Click image for larger version
Name:	bearing seal 2.jpg
BigWhiteRack is offline
post #2 of 6 Old 12-29-2013, 12:09 PM Thread Starter
Ok that seal does just get pounded out from there rear of the knuckle. Its a axle shaft seal..I did not know that was in there..I guess the later 99-03 dont have have that my buddy said, he has a late 99. So I have the seal on order will be in tuesday morning then i can put it all back together..I hope i have the grinding issue resolved with all of this..will see...replaced upper and lower ball joints..the u joint on the axle shaft and the wheel bearing hub assembly.
I really dont think it is the wheel bearing that was making the noise..after inspecting the old one, But will see..
post #3 of 6 Old 12-29-2013, 12:12 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
That type of seal is on all the Super Duty trucks. You also need a special tool to drive it onto the axle and then properly seat it into the knuckle.
dhanna6powerstroke is offline
post #4 of 6 Old 12-29-2013, 12:18 PM
belz's Avatar
Quoted: 68 Post(s)
That is correct.
Belz
CPA Director
belz is offline
post #5 of 6 Old 12-29-2013, 12:20 PM Thread Starter
Thanks for the info..I work at a stainless pipe/fab shop..were the truck is sitting..I will make something of its size to re seat it..If any one could comment on what on how far or what to feel for when i reseat the seal, that would be great..i have never replaced one of these.
post #6 of 6 Old 12-29-2013, 12:26 PM
Mod Newbie
Quoted: 19 Post(s)
This is the tool needed
http://www.amazon.com/gp/aw/d/B0015PKC5W/ref=redir_mdp_mobile
