2000 kepps blowing wiper fuse - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-28-2013, 09:31 AM Thread Starter
My 2000 F 250 has started blowing wiper fuses. Every time it rains and I put the wipers on the fuse blows. It happens when the wipers are on the timer. I haven't noticed any water around the fuse panel,but I know there was a problem with the windshields not sealing well and water dripping on the GEM and fuse box. Any ideas. It started to happen about a month ago when my truck was in for service. I have had a lot of work done over the last few months. Oil pan,timing cover ,CPS,Rear pinion bearing,brakes,etc. When it happened at my mechanics they went to replace the fuse and as the mechanic was putting in a new one his hand touched one of the relays and the truck shut down. Not sure if the two things are related or not. Truck wasn't showing any codes.
JLimb is offline
