HELP weird vibration - Ford Powerstroke Diesel Forum
Old 09-15-2008, 10:59 PM
Hey all, I have a 01' dually. I noticed the top radiator hose has big divit in it where the belt has rubbed on it and it also has wear as it is rubbing on the bottom of the alternator. I looked at my 99' F250 and it has plenty of space between it. Now for my question; The truck has a vibration that i can really feel through the brake and gas pedal. Please let me know what you think.
Thanks Adam
Old 09-15-2008, 11:00 PM
Oh and the truck is stock besides a BHAF air filter.
Old 09-16-2008, 10:09 PM
anyone please
Old 09-16-2008, 10:22 PM
COLLEGE KID
Send a message via AIM to lifewitlooie
Where is the vibration coming from and go underneath your truck and man handle some parts and see if anything is more loose than you think it should be
Old 09-17-2008, 01:42 AM
psd
center bearings and drive shaft or it could be dp pipe hitting cab
Old 09-17-2008, 01:04 PM
Thanks alot guys... I'll check out that stuff and let you know
Old 09-17-2008, 02:36 PM
when you said center bearing are you talking about the carrier bearing
Old 09-17-2008, 10:06 PM
psd
yes the carrier bearing.i replaced it and had my drive shaft balanced and new HD U joints. its all good now!!
Old 09-17-2008, 11:26 PM
It vibrates at idle though too sorry for not specifying that earlier. It's not like a nocking sound its a constant vibration that you can feel in the pedals or through the fire wall
Old 09-17-2008, 11:39 PM
psd
is it a 4/5/6 speed.
