Cold Running Issue - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-24-2013, 05:49 AM Thread Starter
Cold Running Issue
Truck starts fine, the problem occurs when I start driving. The truck will have a bad shutter. Sometimes the check engine light will come on but resets when you restart the truck.
The problem only occurs when it is below 60 degrees and only happens until the truck heats up to operating temp. If I crank the truck and leave it running in the drive way until it warms up to normal operating temp no shuttering or skipping.
Can not seem to figure out what the problem is.
flk9deputy is offline
post #2 of 10 Old 12-24-2013, 06:37 AM
usteffenhagen's Avatar
Subscribed. I may be having the same issue....
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 10 Old 12-24-2013, 06:47 AM
atvrider93's Avatar
Quoted: 8 Post(s)
Likely a bad glow plug or injector or two
sent from me
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #4 of 10 Old 12-24-2013, 06:58 AM
Rule out glow plug because he said it starts fine
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #5 of 10 Old 12-24-2013, 10:39 AM Thread Starter
Cranked truck this morning and let it run to warm up. It shut off two times while it was idling in the yard. Kicked check engine light. Started back up fine each time.
Would a bad injector cause problems only when it was cold?
The truck only has 37,000 miles on it.
post #6 of 10 Old 12-24-2013, 01:51 PM
atvrider93's Avatar
Quoted: 8 Post(s)
One bad glow plug isn't gonna keep the truck from starting.
You really need to read those codes. With so few miles and since it shut off you may be looking more at a oil delivery issue. You really need to get it on a scanner.
sent from me
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #7 of 10 Old 12-25-2013, 01:47 PM Thread Starter
Any chance it could be the CPM?
post #8 of 10 Old 12-26-2013, 11:37 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
no such thing as cpm.
hows your oil? dirty or low?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 10 Old 12-26-2013, 06:46 PM
atvrider93's Avatar
Quoted: 8 Post(s)
You could replace the CPS but that doesn't sound like your issue
sent from me
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #10 of 10 Old 12-27-2013, 07:55 PM
VeggieDoug's Avatar
Just my $.02 on what I did with a similar issue after reading MANY forums....
Replaced glow plugs with ZD11's.....old ones were good...ohm'd them
Replaced UVC gaskets/harnesses....old ones had no signs of short-to-ground, etc
Replaced Engine Oil Temp sensor on backside of HPOP.......bingo!!! 10 bucks later, cold run-til-warm issue solved.
Hope this helps you.
2003, 7.3, auto.
VeggieDoug is offline
