fuel line leak!
Hi,
I thought my drain valve o-rings had gone again even though I replaced them with Vitron units. I climbed under the truck and saw that it looked like the leak was at the union between the stainless looking flex line and the bent steel lines running into the fuel filter bowl. Actually it looked like the steel lines were rusted but I did not want to disturb them until I had the parts on hand. Is there a good online image of that area or does anyone know the part #s ? Thanks!! __________________ |
Do you have a pic? Call Bob at Powerstrokeshop.com
NCH |
Hi, I am travelling on business until Wed, but will take one and post it upon my return- thanks!
ok I will check back
NCH |
Need advice on getting new lines in!
Hi - It was the stainless steel fuel lines (coming out of the fuel filter bowl) that were eroded - you would think that they would not rust but they did.
Any how I picked up new ones, removed the old ones but cannot snake the new ones in. I pulled the old ones out with a bit of force. I have removed the bracket for the PS pump. Do I have to tear the front of the engine off to put these lines in? Help!! |
i think im in teh same boat buddy...just one of my lines was replaced with a rubber hose that im assuming is no longer fully on. do you have pics of the new lins you have? that would confirm it for me
They should route in there but it may take some work and coming in from a different direction.
NCH |
