replaced hpop gasket now truck wont start - Ford Powerstroke Diesel Forum
Old 09-08-2008, 06:40 AM
Just as the title says i replaced the hpop gasket now the truck wont start. Any suggestions? Thanks Chad.
Old 09-08-2008, 06:41 AM
Almostdunfukinwidit
did you fill the reservoir?
Old 09-08-2008, 06:48 AM
Cynic
Did you make sure to hook the IPR back up?
Old 09-08-2008, 06:56 AM
Yea i filled the reservoir and the ipr is hooked up.
Old 09-08-2008, 06:59 AM
Almostdunfukinwidit
How long did you crank it over?
Old 09-08-2008, 07:06 AM
10 or 15 seconds of crank time is all i can get. did that 3 or 4 times.
Old 09-08-2008, 07:08 AM
Almostdunfukinwidit
What do you mean 10 or 15 seconds of crank time is all you can get? are your batteries weak?
Old 09-08-2008, 07:11 AM
yea there weak i got them on the charger right now.
Old 09-08-2008, 07:17 AM
Almostdunfukinwidit
Thats probably your no start condition. The truck will not start with less the 11 volts constant
Old 09-08-2008, 07:18 AM
you may have to crank it for a a bit to fill the High pressure rail. or you could take off the plug and fill it directly.
