2001 7.3 cracking or popping noise high rpm - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-16-2013, 04:02 PM Thread Starter
i have a 2001 f450 with 210k miles
has a popping or cracking noise at high rpm and no load.
it also has a misfire at the point of the sound and a shot of blue smoke out the tail pipe.
I have changed a few injectors and found the noise after doing so. the noise is one crack or pop and gone may not come back for 30-40 seconds and to pop again. truck drives good and cannot hear noise when driving. has a slight miss fire when loaded.
cannot figure it out. sound is louder on passenger side towards front of motor. i have the valve covers off now to hear it better
windydayzz is offline
post #2 of 2 Old 12-17-2013, 11:23 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
bad injector most likely.
you didnt move the long lead injector form the #8 spot to somewhere else did you?
its labeled AE LL its different than the others, the others will be all AD
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
