FUEL LEAK..HELP! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-11-2013, 05:25 PM Thread Starter
FUEL LEAK..HELP!
I have a fuel leak and its dripping out of the hose underneath the water drain switch on the Fuel bowl i think thats what you call it, behind the fuel filter. I have been reading a little and I guess the 0 rings go out or what not.. I need info on what i have to order or what kit i need to get to fix this. Its leaking alot of fuel..
2nd question..This truck is a 99 F350 quadcab dually.. automatic with 157k on it..I live in wisconsin and so winter sucks on these trucks..my question is..every time i start this thing when its cold and cold as in under 40 degrees...lol it starts blowing off pressure intill the truck gets to 150 degrees. I know the exact temp cause i have the edge insight on it. No tunes yet. It kicks its self into high idel intill i hit the gas or break then auto shuts off.. Is this normal, I ask cause i have had a 02 and a 05 duramax and neither did this. Plus my company had a 99 and a 2000 7.3 but they were standards...but they did not do this.. are there upgrades or mods for this..any info would be helpful.. Thanks
ID:	212098   Click image for larger version
BigWhiteRack is offline
post #2 of 6 Old 12-11-2013, 05:36 PM Thread Starter
Also since im at it..This thing is also having problems with cold starts..cold starts as in not plugged in with in 4 hr or so if temp is down around 20 degrees. It will take 4 or 5 trys before it starts..Are the glow plugs weak? The relay seems to be working just fine..I have noticed my battery might be a little on the weak side..thinking about putting a maintainer on it when its plugged in. I have heard that injectors could also come into play with cold starts if they are going. please give my your thoughts or info. Thank you.
post #3 of 6 Old 12-11-2013, 07:20 PM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Ford 7.3 Diesel Fluorosilcone Drain Valve O-rings these are the o-rings for the drain valve. for just a few more dollars you can get a whole rebuild kit.A complete Fuel Bowl reseal kit for the Ford 7.3L diesel filter canister 1999-2003. he has great prices and has a site to help you do maintenance items.Welcome to guzzle's Ford PSD Web Pages
it is normal for our trucks to idle up in cold weather. i believe your work trucks would if you set the parking brake. my bucket at work is a 2011 international and it does the same thing.
Troubleshooting GPR & GP's here is how to test your glow plugs and the relay. with the area you live in it would probably be a good idea to upgrade to a stancor or western snow plow relay.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 6 Old 01-14-2014, 04:29 PM
Planning on doing this soon too. One question I have is is it necessary to do the fuel pressure relief rebuild also at the same time? I dont seem to have any pressure issues but just wonder since I'm going to the trouble to rebuild the bowl. Just curious how many people if any also do this.
STIgone73 is offline
post #5 of 6 Old 01-14-2014, 04:32 PM
studdgage's Avatar
Mine did the same thing i just got the o ring kit and put it in. Come to find out my hard cold start was because of the o ring leaking when i fixed it my truck would cold start np!!
Some people are like slinkies they are completely useless but they still bring a smile to your face when you push them down a set of stairs
studdgage is offline
post #6 of 6 Old 01-27-2014, 03:55 PM
Just curious how bad of a leak you guys are experiencing. Mine is not necessarily leaving a puddle in the valley but you can definitely smell raw fuel after the truck has been driven. I checked around the bowl and all the fittings and connections have dust and grease(assuming from fuel) but I'm not really seeing anything that obvious. You can definitely smell it when you are close to the fuel bowl. Wondering if I should just order the rebuild and passenger side line as well.
