Heater Problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-07-2013, 05:18 PM Thread Starter
Heater Problem
My heater does not always blow hot. For instance monday i started the truck heater worked great, and it continues to work unless i shut the heater off. If it stays off for a few minutes it will blow cold unless i rev the engine to 3,000 rpms. Can rev it in neutral or when accelerating. After I rev it once the heater works perfect. Tuesday I started the truck and heater blew cold, revved the engine once and heater worked 200 miles to my destination.
For all the above instances I wait to make sure the engine is warm.
Any help would be greatly appreciated.
dustys7.3psd is offline
post #2 of 4 Old 12-07-2013, 05:23 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Well if you had a 6.0 Id say that you have a slipping water pump....I wonder if you might have air in the system?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 4 Old 12-07-2013, 05:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Have you checked your coolant level?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 4 Old 12-07-2013, 05:26 PM Thread Starter
Well trucks been doing this for about 1 1/2 years. I replaced the water pump and thermostat about 5 months ago.
