Question - Ford Powerstroke Diesel Forum
Old 08-29-2008, 11:03 AM
International Threat
Question
Will an axle shaft out of an OBS Sterling 10.25" fit in a Super Duty Sterling 10.5"
Old 08-29-2008, 11:09 AM
Ole White
did you break your rearend Marty??
Old 08-29-2008, 11:25 AM
Sure!! Just put the tailgate down! Superdutys carry a LOT!
sorry...just had to say that!
Old 08-29-2008, 01:07 PM
Cynic
I thought the axles were different due to the brake setup on the OBS being on the driveline. No?
Thats Mr. Oil Leak.....
I would think so. All you should need to do is pop the axle shaft out of each and measure them to see if they are the same.
Old 09-01-2008, 08:43 AM
I didn't break one, it was for a friend.
I think the Axle SHAFTS... not the lug pattern/axle itself is the same. Doesn't matter now, chromoly ones will be here Thursday.
