Console inside doesn't work - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-05-2013, 02:00 PM Thread Starter
The upper console inside the cab doesn't work the one that tells mpg, how much further you can go, and the direction. I checked the fuses not that. Any ideas.
bloom7.3 is offline
post #2 of 3 Old 12-05-2013, 02:05 PM
jse51599's Avatar
This is who I used to repair mine. Some of the chips inside the board come loose and some fall off completely.... as mine did.
Ford F150 F250 F350 Super Duty Temperature Compass Overhead Console Disp Repair | eBay
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #3 of 3 Old 12-08-2013, 08:22 PM
bushmogulmaster's Avatar
Pull the cover off and wiggle the connections. You'll probably find that a wiring harness isn't making proper contact, and a little poking around should at least help you troubleshoot. Mine works on and off. If I give it a good smack it usually comes on! Been meaning to do a more permanent fix, but just haven't gotten around to it.
2002 F-250 Lariat CCSB 7.3 PSD; PHP Phoenix (TS 6 position), DIY 6637, foil delete, Banks exhaust brake, air bags | 23x,xxx and running like new on original injectors and hpop ----- Traded (or is that "traitored"?) in for an '05 5.9.
My wintertime diesel toys:
bushmogulmaster is offline
