E99 7.3 runs better when its on the colder side but loses power when warm - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-04-2013, 11:47 AM Thread Starter
chardnay10's Avatar
Ive got an e99 7.3 that runs alot better when the motor is colder vs warm seems as it gets warmer i lose power. Any idea on why? I dont hot rod it when cold but i notice power is alot better cold than hot it has a ts 6 pos, intake, exhaust and has 246k miles
2005 F250 Lariat, SCT X3 with Gearhead tunes, PHP Atlas 40 FICM Tune, 4" Exhaust, K&N Intake, XDP Coolant Filter, EGR Delete, ARP Headstuds with OEM Gaskets, 5w-40 Full Synthetic oil, 8 inch Fabtech 4 link 4.0 Coilover lift. Pioneer deck with 12" Sub, LED Lights all over.
chardnay10 is offline
post #2 of 4 Old 12-05-2013, 05:47 AM Thread Starter
chardnay10's Avatar
anyone?...
post #3 of 4 Old 12-05-2013, 06:23 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
What can happen is, and I'm not saying this is your problem without monitoring the engines sensors, because the injection system relies on oil and oil pressure to drive the injection system, that oil viscosity changing with temperature can have that effect.
What weight oil are you using? Thin Synthetics can show a failing HiPres Oil system early.
How long was the last oil change? Tired oil can foam and do this too.
I would want to get it on a good diagnostic scanner and watch the sensors as the engine heats-up to see if there are any drastic changes.
NoRalPh is offline
post #4 of 4 Old 12-05-2013, 08:35 PM
lookin4myPSD's Avatar
Change the oil. If that doesn't make a difference, then replace the injector o-rings. They can leak when they warm up. And I second the scanner. Watch ICP, ICP duty cycle, and do a buzz test just for S&G.
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
