Battery drain instrument cluster fuse 35 draws 5 amps - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-02-2013, 02:30 PM Thread Starter
OK, I know this isn't the Excursion forum, but it gets more attention/readers, so...
Batteries go dead overnight on my '03 7.3L Ex box. Charging voltage is 14.3+, and near dead battery voltage is 12.2 v. After several hours of charging the beast starts right up, and I can drive it normally all day, with several start/stop cycles. Only aftermarket goodies installed are Edge CTS monitor and DP tuner. They have been in for 2 years, and problem arose recently.
Checked current draw with both batteries disconnected, let module sleep first. Fuse 35 - instrument cluster - pulls 5.3 amps, AMPS not milli-amps! Without fuse 35, total draw is about 20 ma.
Would appreciate advice as to what is next logical step to test. I understand that the cluster is related to a battery saver and/or GEM module, but not sure of specifics for this year.
Any tips on what test process to follow or what to check next from here?
Thanks!
Glen
Flinch is offline
post #2 of 3 Old 12-02-2013, 03:54 PM
How do you check that?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #3 of 3 Old 12-02-2013, 07:18 PM Thread Starter
More details
Drain measured by disconnecting both battery ground cables and putting meter in series with one ground cable and neg battery post.
Yep, get a nice spark off of battery terminals when reconnecting if fuse 35 installed.
My bad: Forgot to mention that fuse #2, Power point - floor console, was blown as well. Have not replace it - tomorrow's job. Also, tore steering column housing off and insulated wire on shift column that goes to tow mode switch on end. Wire had rubbed to expose a bare spot. Not sure if it has anything to do with other issue(s) though.
Glen
Flinch is offline
