02 7.3 no response from fuel peddel intermitten
At times i lose all acceleration it can be from a dead stop alot at macking turns going up heals I have had the cps replaced at the ford house I have traced wiring replaced the peddel sensor it seems like moveing the gear shifter around it will find the sweat spo and take off and I can hold my gear shifter in one spot and it seems to do better any ideals I have read alot of other post and it seems like it is a guessing game alot of people are have the same problem.
Thanks, whitesmoke69 |
Auto tranny?
A little more info would be helpful. Is this all related to the same problem? Your post is a little hard to read and understand because of the lack of puncuation. You are losing power going uphill basically, is that right? |
Sounds similar to my situation. But nothing seems to stop mine from happening. And it's so sporatic it rediculous. Here's the link to my post maybe if mine gets answered it could help you as well.
2001 F250 7.3 drops acceleration to idle |
I'll post the same thing here that I put in the other post...What color is your CPS? If it is gray, change it to the older black ones. This may not be your problem, but it a possibility and it is where I would start.
whitesmoke69
I have looked for the cps multible times and have not found it I am going to go lookagain and see if I can see it and see what color it is. The issue started soon after the ford house replaced the bad one.
thanks, kelly |
More than likely Ford replaced it with the newer gray one. DP Tuner sells the black ones. They are a little pricey, but worth it.
whitesmoke69
Thanks I will try replacing it becuse it is about to drive me crazzy
Thanks, Kelly |
Yeah, I'd try the CPS first. Cheap and simple to replace.
Like I said, may not be the problem, but it's a good place to start.
Let us know what happens... Good Luck |
