surging under light throttle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-27-2013, 02:45 PM Thread Starter
SPY+'s Avatar
ok i looked this up and could not find my similar issue. my 00 f250 is surging from a stop like ill leave a light under normal or light throttle and it acts like i am giving it the beans and then it will act like no throttle at all then just smooth out and acts normal. then when i am on the freeway it dose the same thing from 50 to 65 and dose it the whole time just surging no stop to it at all only when i put my foot in it dose it stop. its driving me nuts i need yalls help
thanks
SOLD:00 F250 CCSB LARIAT 7.3 4'' MBRP TURBO BACK, AIRAID INTAKE, GAUGE POD, INTERNATIONAL UP PIPES,TRANSMISSION COOLER KIT,ADRENALINE HPOP
NEW: 2010 f250 6.4 stock
SPY+ is offline
post #2 of 7 Old 12-14-2013, 08:20 PM
Mine was doing the exact same thing. Light throttle it would do it, full throttle it wouldn't.
A vent line had deteriorated and quiet a few pieces managed to make it into the fuel tank. The fuel pickup screen was plugged along with the mixing chamber. Cleaned everything and did the hutch mod and cleared the problem right up.
63wagon is offline
post #3 of 7 Old 12-17-2013, 05:21 AM
I am having the same problem. I recently replaced the pedal assembly and thought maybe I got a defective part. I imagine this means dropping the tank to check?
2002 F350 XLT SB SRW 7.3
MBRP 5" Exhaust
CAI, TS 6 Pos, 6" Lift
Moto Metal 951
35/12/20 Toyo MT
BTS Transmission
6.0 Cooler, Gauges
Lando302 is offline
post #4 of 7 Old 12-19-2013, 02:33 PM
I had same issue once and it was ICP I had one on there that I bought at oriley and it made it do all kinds of weird stuff took it off and put a ford one on it with a new pig tail wiring and it all cleared up
ccobra70 is offline
post #5 of 7 Old 01-12-2014, 08:34 PM
codyd5051's Avatar
I had a similar scenario last fall, replaced the fuel filter and all was good again. When did you last replace yours? Probably the easiest place to start.
codyd5051 is offline
post #6 of 7 Old 01-13-2014, 03:01 AM
What I ended up finding on mine was some wiring near the drivers side wheel well had rubbed the insulation off of one wire and when ever it would rain or snow the throttle would be inconsistent or not work at all. Fixed the wiring and haven't had any problems yet
MBRP 5" Exhaust
Moto Metal 951
35/12/20 Toyo MT
BTS Transmission
6.0 Cooler, Gauges
Lando302 is offline
post #7 of 7 Old 02-11-2014, 12:30 PM
My truck was doing the same surging under light throttle thing too> Come to find out the square engine harness connector on the inner fender well was all corroded. The pins inside were looking all green and funky. Cleaned all the female pins with piece of braided copper wire and male with a small brass brush. Sprayed the crap out of both pieces with contact cleaner and reapplied dielectric grease. Problem went away!!! I pulled my hair out for months and that all it was! 30 min worth of work!
Jake
Bigjake223 is offline
