P0720 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-09-2006, 06:44 PM Thread Starter
P0720
I have a 2001 Crew Cab, 4x4 DRW with 240,000 miles. I have been getting the OD light flashing and loss of power. When I scan it, I get the P0720 code. The dealer replaced the shifter because they found a short in it and said that should take care of the code. However, it came back again. Does anyone have any thoughts?
bstopek is offline
post #2 of 8 Old 11-09-2006, 06:47 PM
MR.BIGHILLBILLY74's Avatar
Can't help ya with the trouble but WELCOME to the forum from the night crew!
MIKE SELANDER
2004 FORD F350 LARIAT 4X4 DUALLY WHITE AND TAN TWO TONE
SIRIUS RADIO, STAMPEDE CAMO BUG SHIELD AND WINDOW VISORS, HUSKY FLOOR LINERS, CB RADIO WITH DUAL WHIP ANTENNAS, FOG LAMP MOD, HIGH IDLE MOD, LOWARANCE LCX 111CHD GPS, AND DIAMOND PLATE MUD FLAPS
COMING SOON
7" GRAND ROCK MITRE STACKS, AFE INTAKE
:burnout CUSTOM SCT PROGRAMMER WITH SMOKE:burnout
Ford makes it, International shakes it! I'd rather be stroked then rammed! A stroke is at the end of every heartbeat!
MR.BIGHILLBILLY74 is offline
post #3 of 8 Old 11-09-2006, 06:48 PM
If no one else replies try pm Marc and he could probably give ya a hand or any one of the techs
MIKE SELANDER
COMING SOON
post #4 of 8 Old 11-09-2006, 06:57 PM
im fat and ugly
stump0331's Avatar
P0720 IS OUTPUT speed sencor Circuit Malfunction
2004 Excursion
stump0331 is offline
post #5 of 8 Old 11-09-2006, 07:03 PM Thread Starter
How do I fix it?
bstopek is offline
post #6 of 8 Old 11-09-2006, 07:09 PM
im fat and ugly
stump0331's Avatar
sorry not real sure, keep this bumped up and somebody should be along to help
2004 Excursion
post #7 of 8 Old 11-11-2006, 07:20 PM Thread Starter
Seems to happen the most when I put it in 4wd and reverse.
bstopek is offline
post #8 of 8 Old 12-29-2008, 08:56 AM
fynnmore's Avatar
I also got this code this weekend, i was pushing 2' snow amd got stuck real bad. It happened after hours of trying to get unstuck rockin back and forth etc.
Got out and it went away. Check the codes and I got P0720. Could I have just got water or snow in the sensor or was it from all the rocking back and forth from drive to reverse.
Any help would be great!
Fynn
2K F250 4x4 CC-07 front-Alpine HD-4" MBRP-Turbo Life Saver-SCT 3015-AIR RAID Battery Box Intake-Frozen Rotors-Wicked Wheel- Engine/Intercooler Boot Kits-Non-EBPV Pedestal- High Flow Outlet-Banks Big Head Actuator-Pyro, Boost, Trans-Max A/C Assist-08 Tail Lights-HPX-CCV kit- Stancor HD GPR-Pro Comp 2" leveling kit-EBPV Sensor Eliminator Stage II-Over boost anihalator-Mag-Hytec pan-TransGo shift kit-BTS TQ-31r 6.0 trans cooler-BTS valve body-TW tunes
fynnmore is offline
