Blinker, stop light, and hazzrds random operation - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-24-2013, 10:54 AM Thread Starter
mhelm's Avatar
Quoted: 7 Post(s)
I have a 1999 F350 Superduty Powerstroke 7.3L dually super crew that when its cold out, the blinkers, hazards, stop lights will all work. After the truck warms up and the farther we travel the turn signals will disappear, then after a while longer no hazards, if I travel over 1.5 hrs one way the stop lights will stop working. I have replaced the relay in the center of dash, (above gas pedal near the center of truck) I have checked all fuses. Are there any other relays hidden inside??? Why when I loose turn signals do I still have hazards and stop lights. And why do they gradually disappear over time. ( I do notice it happens faster with the heat on high). I am very puzzled, it is the opposite of everything I have researched on the forums. Also what are the two small relays in the same small box with the turn signal flasher. Any help would be much appreciated. Thanks
mhelm is offline
post #2 of 6 Old 11-24-2013, 11:03 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Check your wiring harness that is in your steering column, sometimes it gets pulled tight from using the tilt wheel and can cause some strange lighting issues!!!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 6 Old 11-24-2013, 12:58 PM Thread Starter
mhelm's Avatar
Quoted: 7 Post(s)
Thanks GregSD, I found it. not in the column, but near where those column wires trace back to firewall. If you push up on the harness, the blinkers work, if you pull down, it does not work. I'll have to move the remote start to see whats the problem. And no its not the remote start, I've been installing those for over 20 years & I always solder my connections. pretty sure it a break in the wire or a chaff some where. However I did have to remove the old remote start out entirely and start completely over. maybe I missed something.
mhelm is offline
post #4 of 6 Old 11-27-2013, 07:29 AM Thread Starter
mhelm's Avatar
Quoted: 7 Post(s)
mhelm is offline
post #5 of 6 Old 11-27-2013, 01:07 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Glad to help point you in the right direction!
I am just passing along info that I have read about here in past years
GregsSD is offline
post #6 of 6 Old 08-27-2014, 05:27 AM Thread Starter
mhelm's Avatar
Quoted: 7 Post(s)
RE: hazards, tail lights, and turns problem
UPDATE: The turn signals and the tail light issue is solved, but,,,,The problem of the melting relay is not solved, we just quit using hazards when we pull over. I was told that we have too many light bulbs on our trailer. We have 16 (I think), So if you multiply 16 x 1.5 amps (per bulb) that comes to 24 amp. Which would make sense to why it is melting the 20 amp relay inside the truck. Its that awesome relay under the middle of dash, that some ford engineer had his head up his *** when he said, " oh this would be a perfect spot for the relay" SOB..... We are thinking of switch out to all L.E.D. light bulbs, cheaper than new fixtures. Anyone else have this problem? Or are we chasing our tail??
mhelm is offline
