lost boost? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-23-2013, 11:49 AM Thread Starter
RanchStroke's Avatar
lost boost?
Yesterday while backing up my truck hiccuped and the check engine light came on then went out. I also noticed a electrical burn smell coming from my vents. When I left I noticed on my CTS that I was not registering any boost but could press the fuel pedal and it drove the same as before. Does anybody know where the sensor is the computer gets its boost pressure from or have any idea what else I need to be looking into? Thanks
2006 F250 Kingranch CC 4X4- Totaled 4/28/15 RIP
2012 F250 Kingranch CC FX4- Stock
2000 F250 XLT SC 4X4- FF Stage 1 Injectors, 38R and WW2, Swamps IDM, 6 pos chip from Tony at TDP, CTS Gauges, 4'' MBRP, S&B intake, 20'' Fuel's-305 Dura Grapplers, Smoked Recon light's, HID'S 5K, Ranch hand bumpers
RanchStroke is offline
post #2 of 5 Old 11-23-2013, 02:42 PM
JSchuricht's Avatar
The hickup sounds a lot like a CPS going out. Pull the codes and you should know for sure. I'm not familiar with the CTS but the only stock sensor I can think of to measure boost is the is the MAP sensor. If the CTS has it's own sensor there is a good chance it's teed into the same line.
JSchuricht is offline
post #3 of 5 Old 11-23-2013, 02:55 PM Thread Starter
I got no codes. It is the edge CTS which use to monitor my vitals.
post #4 of 5 Old 11-24-2013, 07:56 AM
blue99stroker's Avatar
Quoted: 243 Post(s)
X2 change cps.
if its not t'd into that line check to see if it runs from the AIH delete hole.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 5 Old 11-24-2013, 06:57 PM Thread Starter
Found my electrical burn smell, it was one of my hid lights smoked. Also I reset my cts and boost started to register again. Only thing I am concerned about now is why the hiccup. It acted like it was going to die along with a check engine light then it didn't. I got home and pulled the codes and there was none that came up. Any ideas? Thanks
