Fuel Trickling From Filter Drain Hose - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-21-2013, 07:30 AM Thread Starter
RadarRider's Avatar
Question Fuel Trickling From Filter Drain Hose
Time for another horrible explanation of a problem I've got. LOL I'll try my best this time:
The road in front of my house has a slight incline. The other day, I pulled my truck out of the driveway & got out to talk to my wife, leaving the truck pointing down the hill. When I walked back to the truck, there was a steady trickle, almost a stream of fluid coming out of the bottom radiator area. At 1st, I thought it was coolant, but after a quick sniff, it turns out it's fuel. I drove the truck to a friend's house & parked it on level ground. After about 20min., I went to check to see if there was a stream & it looks like it only dripped a couple of drops. Yesterday, I was looking for a vacuum leak under the truck(my driveway is level) & I noticed the hose for the fuel filter drain was saturated & it has dripped enough times to make a spot about the size of a half-dollar. I went up top to make sure the drain lever was in the right position & it is. The cap & housing is bone dry. However, the lever seems to move a little more freely than I remembered it to.
Performance-wise, the truck feels like it's running like a top, so I don't imagine the leak in it's current state is causing problems. But I'm sure this isn't a problem that's going to get better, it's probably going to get worse, right? Has anyone else had this happen to them? Where do I start looking?
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #2 of 7 Old 11-21-2013, 08:50 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
I'd be thinking it's time to do this -> Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
NoRalPh is offline
post #3 of 7 Old 11-21-2013, 09:09 AM Thread Starter
RadarRider's Avatar
Originally Posted by NoRalPh View Post
Hmmmmm....very interesting. Doesn't seem like a hard job. I'll give this a shot. Do you think I could just get these O-rings matched at a parts store? Or is this kit Guzzle has Ford p/n specific? Just wondering to see if I can save some time.
post #4 of 7 Old 11-21-2013, 11:01 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
beat me to it...it's caused (usually) by the ULSD that our trucks wernt designed for.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 7 Old 11-22-2013, 07:14 AM
Quoted: 157 Post(s)
In a pinch, I'm sure any new O-ring the right size will work OK...
BUT, if you're going to be maintaining your truck and haven't replaced a lot of this stuff already, I'd be thinking this too -> "Mechanics Parts Cabinet" Combo repair kit for common Fuel and Oil repairs 99.5-03
In it, the only option for better O-rings happens to be those you need so, regular "part stores" rings can be much improved upon
When I bough that kit I ponied-up the coupla bucks for the better ones but haven't used them yet.
NoRalPh is offline
post #6 of 7 Old 11-22-2013, 07:59 AM Thread Starter
RadarRider's Avatar
That's one thing that's bouncing around in my head is Viton quality vs. Napa quality. The only thing that's stopped me from going down the street is wondering if I'll get years of service out of something as simple as "any old O-rings", or having to take the valve apart in a few months because I didn't pony up the extra bucks, especially on a job that appears "easy" but needs careful attention to detail. I think I've got enough time to wait. I'm just going to buy the kit from Guzzle. I'm the type of person that needs the piece of mind.
post #7 of 7 Old 11-24-2013, 09:07 AM
Joel's Avatar
Quoted: 10 Post(s)
Mine was leaking bad and I need it fixed ASAP.
The ford dealer wanted like $89 for two orings, soooo I used a little RTV and it worked for a few months.
I used that borrowed time to order the mechanics kit from RiffRaff.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
