Truck dies while running. Won't start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-19-2013, 02:30 PM Thread Starter
r_marczak_83's Avatar
Like the title says, the truck died while cruising down the road. It will not restart and the "wait to start" light doesn't come on anymore. I checked some fuses/relays under hood, but no luck.
Any suggestions?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 6 Old 11-19-2013, 02:42 PM Thread Starter
Also, I thought I ran out of fuel since low fuel light was on. I put 3 gal in and that's when I noticed no wait to start.
E99 F250 ex-cab 7.3
post #3 of 6 Old 11-19-2013, 04:47 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
No WTS means the PCM isn't running. It's Never gonna start that way, don't waste the batteries trying....
In the Vast majority of cases, especially this time of year, it's the fuel heater being turned-on for the first time and blowing the fuse (yea, I know, you checked them - do it Again ) I would unplug the heater (at the bottom of the fuel bowl) and replace fuse #30 just to be sure...
NoRalPh is offline
post #4 of 6 Old 11-19-2013, 06:29 PM Thread Starter
Is that #30 under the dash or in engine bay?
I never checked any under dash.
E99 F250 ex-cab 7.3
post #5 of 6 Old 11-20-2013, 07:05 AM
Quoted: 143 Post(s)
You want to check all of your fuses! Everywhere
Not sure about your truck, sometimes it's #22 under the hood on earlier trucks. Mine ('02) is under the dash #30 for the Fuel Heater / PCM...
NoRalPh is offline
post #6 of 6 Old 11-20-2013, 04:11 PM Thread Starter
It was the #30!
I unhooked the fuel bowl heater and replaced. Started right up!
Thanks!!!
E99 F250 ex-cab 7.3
