7.3 dying at stoplights but will restart - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-19-2013, 08:58 AM Thread Starter
kbragg430's Avatar
So i have a 2002 7.3 f350. It keeps dying after it sits for a few seconds at stoplights and such. Its like it bogs down and just shuts off when i hit the pedal. But after i turn on my flashers, slip it into neutral and slam the pedal, it will get through the bogginess and roar away. I just resealed my fuel bowl and my hpop. Could it just be air in the system still causing it to do this? Its only been driven about 30 miles since sitting for a few weeks. Any help?
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #2 of 8 Old 11-19-2013, 09:01 AM
luke7.3's Avatar
Quoted: 24 Post(s)
almost sounds like clogged air filter. WHens the last time youve cleaned or replaced you intake filter?
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #3 of 8 Old 11-19-2013, 09:04 AM Thread Starter
kbragg430's Avatar
I have the diy tymar type. And its only like 4 months old
331 hp / 620 tq
post #4 of 8 Old 11-19-2013, 09:16 AM
luke7.3's Avatar
Quoted: 24 Post(s)
rules that out... does the truck seem to die down when you apply the brakes?
Luke
luke7.3 is offline
post #5 of 8 Old 11-19-2013, 09:31 AM Thread Starter
kbragg430's Avatar
No and it idles fine. Only when i go to hit the gas after sitting. It bogs down and dies
331 hp / 620 tq
post #6 of 8 Old 11-19-2013, 09:35 AM Thread Starter
kbragg430's Avatar
Well just popped the hood and looked around and somehow my ipr managed to back itself out. Im guessing that would be the problem?
331 hp / 620 tq
post #7 of 8 Old 11-19-2013, 09:56 AM Thread Starter
kbragg430's Avatar
Not the ipr itself. Just the spacer and nut
331 hp / 620 tq
post #8 of 8 Old 11-19-2013, 10:16 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes sir that is most likely your problem. You can buy a rebuild kit from dieselorings.com. The tin nut most likely is shot so even if you tighten it it may happen again
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
