2003 7.3 SES on start then lopes after - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-17-2013, 03:53 PM Thread Starter
Hi guys,
I just picked up a 2003 7.3 6 speed 170K. I bought the truck under the assumption that the turbo was blown based on the dealers assessment. The good news is that it was wrong and the turbo appears to be in great shape. No play and spins nice.
When started cold the SES light comes on at start up and stays on until the truck is warmed up a bit. During this time, the engine idles smooth but is very sluggish to rev and stumbles at 2k rpm and if pushed beyond that just blows white smoke really heavy. After a while the light goes out and the truck does a few bad bucks and sort of smooths out but still has a lope especially when letting off of the pedal. it drives ok but has some hesitation.
After it is warm if I shut it down and restart it, the SES light comes on initially with all the same symptoms as well as not wanting to build any boost. after 30 seconds or a minute the light will go out it will lope real bad then mostly calm down.
I have recently been using the torque app. At idle the HPOP is right at 500 psi maybe a little shy. The IPR duty is around 15% when pushed hard, the HPOP gets up to about 2600.
I have tried checking for codes with torque and it turns up nothing.
My thought is that for some reason at start up its in some sort of limp mode then kicks out of it but actually runs worse. What would be changing or what would the computer be monitoring that would result in those symptoms after it comes out of limp mode?
Any ideas or suggestions are greatly appreciated. I just changed the oil because it looked a little dirty. Also changed the coolant. It looks as though it may have previously had oil in the degas bottle at some point.
Thanks
Matthews is offline
post #2 of 12 Old 11-19-2013, 11:16 AM Thread Starter
Does anyone have any ideas for me?
Matthews is offline
post #3 of 12 Old 11-19-2013, 01:42 PM
HillbillyDeluxe39's Avatar
Did you check/change the fuel filter?
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #4 of 12 Old 11-19-2013, 01:55 PM Thread Starter
The fuel filter looks to be pretty new.
I thought about the fuel thing but I couldn't make sense of why suddenly the computer would kick out of it and allow it to fuel and build boost
Matthews is offline
post #5 of 12 Old 11-22-2013, 07:26 AM Thread Starter
Any other ideas floating around out there?
Matthews is offline
post #6 of 12 Old 11-22-2013, 07:58 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well im gonna say your ICP or something on the oil side is bad, go out and unplug the ICP and look at the plug to see if theres oil(indicates its going bad not necessarily bad yet) and then try starting it unplugged and see if it runs better if it does the sensor or pigtail is bad. The 7.3 needs a MINIMUM of 500 psi to run, so if what your saying that its dipping below 500 its probably pissing the PCM off and its letting you know.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 12 Old 11-23-2013, 07:06 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
X2 on the icp.
oil isnt low is it?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 12 Old 11-23-2013, 09:09 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Why Guess though.....?
Get the engine on a proper diagnostic machine, pull the code that's setting the light, and monitor what's going on while this is happening. The cost for the scan might save you Lots of money over buying expensive sensors you don't need
OR, if you intend to keep the truck for a while and do the work on it yourself, invest in the right scanner (most here use the AutoEnginuity, @ $350 w/Ford Enhanced pkg)
NoRalPh is offline
post #9 of 12 Old 11-28-2013, 05:06 AM Thread Starter
The ICP appears to be dry and when I look at it with tourqe it is reading. It makes no difference to run it with the sensor unplugged. The oil level is not low.
I am working at getting a scanner on it, I'm not sure about you, but $350 is still a lot of money for me.
Anyone with auto enginuity in the Cincinnati Ohio area that's will to hook up to this truck and tell me what it says?
Matthews is offline
post #10 of 12 Old 11-28-2013, 08:30 AM
Quoted: 157 Post(s)
Yes, of course it's not cheap...
But, and why I asked, if you plan to keep your truck and maintain it yourself, it could actually save you money You're using the TorqApp? You can't get any cheaper than that and still get a lot of useful information (Much better than a generic OBD-II).
What are your ICP pressures? Did you say it's No Different plugged/unplugged? Like 2300? That's not right!
This is what you should be able to see from the sensors (from the AE Forum)
Set up AE to monitor ICP and IPR duty cycle and crank it over. When you first turn the key on, you should get 14% IPR, and when you crank it, ICP should come up to 500 psi plus and IPR should be probably no higher than 25% or so. If IPR goes above 35% then you may have Injector o-ring leakage. That would explain the long crank times. You may also want to check cranking RPM, which should be a minimum of 100.
More good ICP info here-> 7.3 icp and duty cycle Page1 - Diesel Power Forums at Diesel Power Magazine
NoRalPh is offline
