99 SD F350 7.3l Not Starting - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-16-2013, 04:49 PM
Jadebortoli
Guest
Posts: n/a
Quoted: Post(s)
Truck doesn't start unless I spray wd40 in the air intake. Once it starts it runs great. Any ideas?
post #2 of 4 Old 11-20-2013, 02:28 AM
r_marczak_83's Avatar
Quoted: 2 Post(s)
Is this only when cold or when warm too?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 205/100's, 17* HPOP, 140v Swamps IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #3 of 4 Old 11-20-2013, 07:38 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
stop spraying stuff in the intake now,
these trucks do not take ether, wd 40 or any starting fluid, EVER
are you having cold start issues?
read the sticky about winter, hard starts etc.
these trucks also come equipped with a block heater, if yours has never been used its tied up behind the grill drivers side.
use this until you get the glow plug system working like it should be
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 4 Old 11-21-2013, 11:03 AM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
wow just wow... start here 7.3 Tech Files - Ford Powerstroke Diesel Forum then if then you have questions check here link
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
