Cackle after hutch mod - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-14-2013, 06:35 PM Thread Starter
Did the hutch and harpoon this weekend now I hear what I think is the cackle sound. Also there appears to be air in the pre pump screen. Not sure if the bubbles are caused by the screen or not. I watched the fuel bowl fill up and saw no bubbles. I didn't notice this cackle or slap sound before I did the mod. Am I paranoid?
Fuel filter
IMG_0132.mp4 Video by AUbronco | Photobucket
Cackle sound
IMG_0127.mp4 Video by AUbronco | Photobucket
Here is my original post on how I did the mod.
Newbie here. I just completed the hutch and harpoon mod on my recently purchased 2001 Crew cab. I just want share how I deviated from some of the other ways guys have done this. I referenced the below links the most for my mod.
Parts are:
3/8"x8" uncoated brake line
5/16"x40" uncoated brake line (could have used 30")
5/16"x3' 30R7 Fuel Hose
Napa #3007 fule filter
3/8" compression fitting
5/16" compression fitting
My version is pretty much like everyone elses except I wasnt able to reuse the black foot and I couldn't wait to order a new one. I just have the flared end of the 3/8" brake line facing down. Also, the leght I cut it was 3.5" base on my measurements. Most peoples are a little longer, maybe I had a little different compression fitting. Also I reused the hardline that is on the frame rail. I found that after cutting those off the 5/16" line fit more snug than 3/8" line. This was good as it solved the problem from necking down to the 5/16" inlet of the fuel pump.
Auburn08 is offline
post #2 of 5 Old 11-14-2013, 07:32 PM
timmyboy76's Avatar
double worm the line off the tank.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 11-15-2013, 03:19 AM Thread Starter
I used 5/16" hose from there to the stock hard line. It was I tight fit on the pickup side and the hard line side even without the clamp.
Auburn08 is offline
post #4 of 5 Old 11-15-2013, 09:27 PM
timmyboy76's Avatar
hows the "return" line routed in the tank? Only other air present possibilities, is at the feed line at tank or the clamps at filter...
post #5 of 5 Old 11-16-2013, 05:32 AM Thread Starter
It's routed out passed the float. The way the hard lines neck down could act kinda like a nozzle and I wonder if it is aerating the fuel as it passes through.
Auburn08 is offline
