HELP!!! Truck won't start... - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-14-2013, 03:28 PM Thread Starter
Let me start from the beginning. I have had a cracked block since I bought the truck. Over the last few months I have overheated it and blew a head gasket. 2 weeks ago I removed the head sent it to a machine shop. They decked the head and told me that my injector cups were leaking this is why I had puking out the degas bottle. I replaced the injector cups, followed the torque specs on head, replaced orings on oil cooler, changed oil, rebuilt fuel bowl, replaced copper washer on injector, I did not replace orings since they were only 3 weeks old.
Now that this is all together I tried to start it. For 2 days I cranked and cranked. ICP 2000-3000 voltage 10.5-10.9 cranking. I don't know what my fuel pressure is but I have fuel pressure. I did a KOEO test with a normal ROM error. I checked all of the fuses one was bad I replaced it. I did a buzz test all injectors fired. The tach was 200 RPM. I changed the tune from 60hp to modified stock. And I changed the CPS to a ford CPS.
Today I decided to do the no no and use starter fluid. I disconnected the glow plug relay and started it. It would not stay cranked nor did any oil come out of the oil spouts. I removed the oil plug inside the valve over and am getting oil out of it.
I don't know what else to try. Any help please....
2000 F250
ZF6
EBV Delete
DieselRX glow plugs
Zoodad
Muffler Delete
Rancho shocks
6637 Mod with riffraff cover
Riffraff billet compressor wheel
Rishsd is offline
