Wont start worth a crap when cold (I know there are threads, but just read) - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-13-2013, 10:59 PM Thread Starter
r_marczak_83's Avatar
Quoted: 2 Post(s)
I gat this truck 3 years ago. After the first winter I put a new GPR from NAPA in it and a new block heater. The following summer I put new Glow plugs in it. Last winter I put 2 new NAPA batteries in it, plus a new starter & new alternator.
You would think I should be good to go. Every time it gets down to the low 50's, it's sluggish at starting. But starts.
Yesterday it was 40 out and wouldn't start. Bogged down after I cycled GP's twice and acted like I had dead batteries.
What can I look at now to make this thing start when it's cold?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 205/100's, 17* HPOP, 140v Swamps IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 14 Old 11-13-2013, 11:13 PM
schlutzer's Avatar
Quoted: 18 Post(s)
If you are spinning too slowly itll be tough to start regardless so I have some suggestions based on my own truck.
Test that NAPA relay, they aren't known for longevity.
Check out your battery cables, every SD I've seen uses a open terminal on the starter, this means your starter cable looks like crap after just a few years.
I built my own on my E99 out of 3/0 with crimped closed terminals and it made a HUGE difference.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 14 Old 11-13-2013, 11:26 PM Thread Starter
Quoted: 2 Post(s)
Ok, Thanks Ill probably replace the starter cable reguardless then.
How do I test the relay? It hums and makes a click noise after about 30 seconds.
E99 F250 ex-cab 7.3
post #4 of 14 Old 11-14-2013, 12:33 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Get a voltmeter and a buddy. Have your buddy turn the key forward while you test the voltage across the big terminals. Should read the same as your battery voltage.
post #5 of 14 Old 11-14-2013, 12:35 AM Thread Starter
Quoted: 2 Post(s)
Ok. I will do that today.
E99 F250 ex-cab 7.3
post #6 of 14 Old 11-14-2013, 09:48 AM Thread Starter
Quoted: 2 Post(s)
With the key "off" the voltage across the BIG terminals is 12v. When the key is turned "forward" it goes to .005v.
Is this right?
E99 F250 ex-cab 7.3
post #7 of 14 Old 11-14-2013, 09:59 AM Thread Starter
Quoted: 2 Post(s)
CORRECTION.
I didnt know how to do the measurement, so I looked it up.
From one terminal it had 12.3v with key "off". The other had 0v.
With key "on" I had 12v on one terminal (original 12.3v one) and had 10-9.9v on the other.
Is this bad? Since its lower on Voltage than the other?
E99 F250 ex-cab 7.3
post #8 of 14 Old 11-14-2013, 10:17 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
The way to test it is to put the ground lead of the test meter to a good ground, then have some one turn the key on, then touch each of the big terminals and compare the two numbers. They should be the same or damn near the same otherwise the relay is toast
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #9 of 14 Old 11-14-2013, 12:36 PM Thread Starter
Quoted: 2 Post(s)
Well there is my numbers. 12 & 9.9. Is that close?
E99 F250 ex-cab 7.3
post #10 of 14 Old 11-14-2013, 12:41 PM
Chapter Director
Quoted: 5 Post(s)
Nope relay is toast, Minimum i would say is 11v Replace it with this relay Western Plow GPR Relay
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
