No Power, Shakes - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-10-2013, 05:06 PM Thread Starter
No Power, Shakes
Today, coming home from 200 mile trip, I noticed a vibration that I initially thought was the road. Within a few minutes, the condition worsen to the engine had no power, shaked badly and eventually stalled. I was able to get it off of the road. Road side inspection, everything looked ok. Oil level good; oil looked & smelled ok; fuel filter looked ok. I was able to get the engine restarted but still no power and shaked. No check engine light. Fuel was at 1/4 tank. Truck has 103K, has been well maintained. Fuel filter 12k, oil 3k, etc
Thoughts?
2002, F350, CC. No mods less AIS Intake
h20camper is offline
post #2 of 10 Old 11-11-2013, 06:28 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #3 of 10 Old 11-12-2013, 11:19 AM
jec92's Avatar
Same problem with my 99 f350. it will crank and run fine. after about 5 miles it will start skipping and missing and eventually stall out with no power. after a few hours i can crank it back up and will run fine for a while. i changed the fuel pump and filter still no luck
When the going gets tough...the tough gets going
jec92 is offline
post #4 of 10 Old 11-12-2013, 11:39 AM
Quoted: 769 Post(s)
Sounds like a UVCH plug is loose
Corey@CNCFAB is offline
post #5 of 10 Old 11-12-2013, 11:55 AM
jec92's Avatar
ive thought of changing those on mine but leaning more towards an icp becuse its throwing a code for one
jec92 is offline
post #6 of 10 Old 11-12-2013, 12:01 PM
Quoted: 769 Post(s)
Just unplug it and start it up. It will throw it into limp mode. Also look for any oil inside the plug. Don't just throw parts at it.
post #7 of 10 Old 11-12-2013, 03:37 PM
jec92's Avatar
I unplugged it and it seemed to run worse so I'm guessing that icp sensor is not my problem?
jec92 is offline
post #8 of 10 Old 11-12-2013, 03:52 PM
Quoted: 769 Post(s)
Unplug one of the injector harnesses. Then the other. Then start it.
post #9 of 10 Old 11-12-2013, 04:50 PM
Quoted: 769 Post(s)
One other thing. Since you said you were at 1/4 tank of fuel. Your pickup tube in the fuel tank may be broke off at the bottom. Look up hutch and harpoon mod.
post #10 of 10 Old 11-13-2013, 05:36 AM Thread Starter
I have the truck at a shop I trust. They hooked her up to the computer. No codes can by found. Injector test passes. Fuel pressure is good. Everything I read points to the UCVH less the tests they have ran. Gonna cost me ~$200 for the shop to open and inspect both valve covers. I think I read at some point, Ford designed the UVCH so it stays clamped together better. Being a 2002, which is towards the end of production for the 7.3, I was thinking my truck might have the redesigned UCVH.
