Best coolant - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-09-2013, 07:58 AM Thread Starter
pudil45's Avatar
Send a message via MSN to pudil45
Best coolant
What's the best coolant for my 7.3? Seems like my truck just drinks it faster than I can fill it
Sent from AutoGuide.com App
2001 F 350 DRW
7.3 Powerstroke
4 inch downpipe to 5 inch mitre cut stacks
Southbend Dynamax clutch
DP Tuner
2006 F-450 6.0
Bone stock
Whelen Justice Wecan
Aluminum 11' bed with folding sides
pudil45 is offline
post #2 of 6 Old 11-09-2013, 10:24 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
if your losing coolant thats not good.
a better coolant isnt going to fix that.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #3 of 6 Old 11-11-2013, 11:20 PM
Good - Ford Green
Better - Ford Gold
Best - Aftermarket HD ELC (Usually Red)
For the record, I dont recommend Ford Green, and recommend the ELC, but gold will do.
Also, if your truck is drinking coolant, the last thing you want to do is waste money putting better (more expensive) coolant in. Get it fixed.
Also, you should note, colors dont matter outside of Ford. Ford uses colors to distinguish their coolants, but a Ford Green and another manufacturer (eg, Prestone) are NOT the same. You should not be running any coolant that is labeled "All Makes and Models", "Mix with any color", "Any Vehicle" etc etc...
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
05 Conversion - 50" LED Light Bar - MBRP 4" Exhaust - AIS Intake - PHP Tuned
USA - Thank you those who serve
A/Ox3 is offline
post #4 of 6 Old 11-11-2013, 11:32 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Question
Originally Posted by A/Ox3 View Post
Good - Ford Green
Better - Ford Gold
You neglected to say that you shouldn't put Ford Gold or any other ELC coolant into a truck not designed for it. If your truck came with green, stick with it. The seals in the front cover were updated for ELC as it reacts to the older sealant
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 6 Old 11-11-2013, 11:48 PM
I didnt neglect to say that. I chose not to. I have never ever heard of any e99 trucks having issues with gold or ELC coolant, and I have seen several run it.
Also, T444Es were run with ELC, including their 99 year engines. Sooo... Dont run it if you dont want to. But until I see actual evidence, I will stick with ELC as my recommendation.
A/Ox3 is offline
post #6 of 6 Old 11-12-2013, 06:31 AM
DieselManor's Avatar
Check the weep hole on the water pump. Could be loosing the coolant there. Hope so, otherwise you may have other problems. Fix the leak first. Check the overflow (de-gas) cap for proper pressure. If it's weak you could be loosing it there, but that will probable show as a full overflow bottle and you'll be able to see it leak out the relief hose. You'd probable smell it too. If your pump is bad you'll be able to smell it there too. Otherwise it could be a head gasket. I don't say that to scare you, but it's another possibility. That should be easily found, look at the oil. If it looks like chocolate milk... guess what?
I run Zerex in the white jug in my 7.3L and then just add the Fleetguard DCA4. We sell a lot of the Fleetguard Lifetime coolant too, but I personally put in what was intended for the system. I've had no problems other than having to replace the water pump a year ago.
Cooling System Products at DieselManor
Hope that helps.
David Murphy
DieselManor is offline
