problem or overload? - Ford Powerstroke Diesel Forum
Old 08-02-2008, 05:33 PM
first, what is the max load a 99" f250 ext cab 2x4 can pull?
thanx in advance!!!
Old 08-02-2008, 05:42 PM
aluminum tubing engineer
diesel or gas...legally or illegally...flat terrain or mountains...comfortably or barely...
...so many questions
ill guess a PSD since we are in that forum
max trailer 10,000 and max combined 20,000
Old 08-02-2008, 05:57 PM
well its a psd of corse since thats kinda what this forum is about-lol
but i will go on and start the long story.
this morning i got called into work to go lay block and met a co-worker at the shop that drives the truck discribed and loaded these huge 80 lb. block.
so they were on pallets and they were so heavy that when the forklift tryed to pick it up the pallet just fell apart.
but there was 36 blocks per pallet and we put 4 pallets on the tralier so all together its 11520 lbs. + tralier
so when we took off it had a little trouble takin off but we had to climb this little drive way that was the deff. of steep! and about 500 ft long.
so we got to the top and still sitting on the hill we unloaded another trailer and while we were trying to back it up i noticed oil on the driveway startin where he started backin up and it was trany fluid so i stoped him and we unloaded there and left it sit and thats where its at now.
is there something wrong or did it just over heat?
sorry for the novel
Old 08-02-2008, 06:13 PM
Sounds like he blew the front seal on the tranny. My dad did this a month ago.
Old 08-02-2008, 07:40 PM
Send a message via AIM to ford_trck
The front seal sounds right. I've heard of this going 2 ways. I have one friend that got lucky and he just parked the truck a couple days topped of the fluid and didn't have any problems. On the other I konw another guy that just parked the truck pulled the tranny and replaced the seal.
Old 08-03-2008, 06:22 AM
well we went to get it this mornin and just got back but started fine and went into drive fine (trailer empty) and we watched the trans for leaks and nothing, drove on up the hill and turned around and went back to the shop and checked the trans fluid and it was just off the full mark. so did it just get hot and over flow or further problems?
Old 08-03-2008, 06:35 AM
Jon
Guest
Posts: n/a
Well
more then likely its the convertor seal in the front of the pump. It will probably be ok till the next time you pull or get it hot enough to leak again.
Old 08-03-2008, 06:44 AM
well dang!!!!!!!! that is the whole point of haveing that truck-pulling
Old 08-03-2008, 07:42 PM
yes...but when you pull over weight...and up a steep grade...well...you get the point
...so all together its 11520 lbs. + tralier ...but we had to climb this little drive way that was the deff. of steep! and about 500 ft long.
Old 08-03-2008, 07:47 PM
Backing up heavy trailers in reverse on a hill hurts tranny's. It hurt my dads 4R100 and it broke 2 of my 5R110's.
