Losing elecrical power then stalls - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-03-2013, 11:32 PM Thread Starter
snowmobiler7c's Avatar
I have a very stange issue. I have a 2003 F250 7.3L CC with 150k. Today i drove it about 60 miles to pick up some snow tires for my mustang. I am almost to my destination when the radio starts to die. Then the odometer and trip computer start to dim out and the abs light comes on, then while still traveling at 50mph the speedo/rpm guage go to 0 while the motor is still running. So i assume the alternator which is 8months old is bad again. I pull into the guys driveway put the truck in park and it stalls. After i get the tires i go out truck cranks over nicely and starts. Everything has power again for about 2miles then the truck stalls while driving. This happened several times while i was trying to make it to the closet auto zone. After only making it about miles from the guys house I finally gave up and called AAA to have it towed home. When i got home truck still would start and run for about 2min slowly losing power and stalling again. If i start the truck and put a load on it like turning on the headlights truck will stall out.
So this afternoon i pulled out both batteries and put them on a trickle charger. I plan on pulling off the alternator tomorrow and taking it into autozone to be tested. What else could it be? I have never seen a vehicle with a bad alternator still start after losing power like this. It dosnt make any sense to me. Any suggestions??
snowmobiler7c is online now
post #2 of 5 Old 11-04-2013, 10:18 AM Thread Starter
Alternator test good. I really hate to have this towed to the dealer any suggestions??
post #3 of 5 Old 11-20-2013, 08:28 PM Thread Starter
I have not had any time recently to work on the truck but really need to get it back on the road, any suggestions?
post #4 of 5 Old 11-21-2013, 05:01 PM
Electrical gremlins
I had the same issues happen to me, ended up being the factory battery terminals had corroded from the inside where the leads connect. There was no visible sign of corrosion. So as not to have it happen again, I bought marine terminal and had the leads re-crimped. Make sure to do both the positive and negative. It hasn't skipped a beat since...
smith825 is offline
post #5 of 5 Old 11-22-2013, 10:31 AM
schlutzer's Avatar
Quoted: 18 Post(s)
x2 on the battery terminals... in this case especially the ground.
My passenger side ground had started to cut through from rubbing.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
