starting problem
My 2000 F-350 7.3 was getting slow to start and I noticed corrison on my battery terminals, so I cleaned all posts and cables on both batteries. Then a couple of days later the truck won't start at all, it wouldn't crank, just clicked...So I replaced both batteries, which were well over 3 years old. But this didn't help. The truck still won't crank, it just clicks. What could or would be my next step.
Thanks |
i would also check the starter switch,
Thanks, got it fixed...It was the starter. Thanks again for the suggestions...
mines gettin kinda slow... all connections are good.
after it starts, i noticed it going WHEEEEEEEEE as the starter spools down and the engine is running. is this normal? 96 f350 209k mi Last edited by POWERSMOKIN; 08-16-2008 at 10:45 PM. |
![]() ![]() ![]() Sorry, couldn't help myself! Hope you find your answer soon. At least I bumped you back to the top. |
![]() ![]() ![]() ![]() That was good! |
Describe the 'WHEEEEEEEEEE' sound. There might be a possibility your input gear is still spinning after it's been disengaged. You can bench test your starter to see if this is the problem.
its just like, a whirring, not like an overused pencil sharpener with a shot bearing, just like the clutch opened up, and it goes from like 1,500 rpm to 0 winding down, but ive never heard any other starter do that.
How would i bench test it? and where is it at? |
