Engine dies and no codes. - Ford Powerstroke Diesel Forum
Old 07-28-2008, 08:00 AM
I had my truck die on the interstate last week. Thought it was classic CPS problem even though I had the CPS recall done. I get it to the shop and he replaces CPS (it had read a code for CPS) and truck fires right up. He runs it down the road and truck dies with scan tool in truck. No codes.
Any ideas. Had injector work done and have run tranny fluid through three tanks to clean up others. Truck had plenty of power so I don't see that being an issue. Truck just dies for no apparent reason.
Mechanic has my truck and cannot find a cause. Please help me lead him.
Old 07-28-2008, 10:00 AM
Send a message via AIM to blizzardwarrior7
Does it die all of a sudden? Or does the idle get rougher, and than it dies?
Does it die instantly? Or does the truck warm up, and than die?
Does it always die completely? Or can you hear it start to go, and then stop it?
Old 07-28-2008, 10:07 AM
Died instantly. Shuddered for about 1 second and then the engine just stopped. Wouldn't start back up. SHe was very warm, city traffic for about 15 minutes and then 30 minutes of interstate driving at 90+ degrees.
As far as mechanic testing her now, I do not know but same thing, she just dies and doesn't trip a code one.
Old 07-28-2008, 10:36 AM
sounds 2 me that there somthing wrong with hpop or an ipr sensor
Old 07-28-2008, 11:45 AM
Yup, I agree, something oil related, maybe IPR O ring.
Old 07-28-2008, 05:30 PM
did you check the oil level? mine did the same thing after i had my cps replaced. ended up being 5 quarts low on oil!!!
Old 07-29-2008, 10:23 AM
Yea, dirty oil or low oil can cause similar symptoms, but its USUALLY not that simple .
Old 07-29-2008, 10:35 AM
Check the uvch...under valve control harness. I was told they can get old and fail
Old 07-29-2008, 12:22 PM
Have you had your EGR valve cleaned lately? I had mine get stuck open and didn't throw a code. The engine died and wouldn't start. I removed the valve, cleaned it and have not had any problems since.
