NEED HELP Edge Juice - Ford Powerstroke Diesel Forum
Old 07-25-2008, 10:39 PM
Send a message via MSN to Scooter9495 Send a message via Yahoo to Scooter9495
Hi everyone, this is my first post and i have a problem and couldnt find anything under search.i have a 2001 excursion 7.3 and it runs perfect, i installed an edge juice with att. today and when i started it, it ran like crap, idle surge,push the pedal and doesnt even want to rev., hold pedal to floor and revs SUPER slow, let off and it dies.Checked all connections several times,went back to factory and runs perfect again. ANYONE ELSE HAVE PROBLEMS LIKE THIS? Juice bad?
Old 07-25-2008, 11:36 PM
i actually heard the Edge brand of performance chips for a powerstroke is the bomb. My 6.0L is actually in the shop right now. My truck had an edge on it for about a week and when i put it on it ran like crap but i didnt do it right. I took it to my diesel mechanic and he rehooked it up and it ran like a charm. No Chipped up cummins or Duramaxie pad could touch me. I took it off because i needed some money.
Old 07-25-2008, 11:52 PM
Thumbs up fix psd
well it sounds like the plugs are not clean and or the tap at the icp is not in there good.there is a plug for the map ,to check all hook ups and back track your hook ups you,ll find her.dont floor it until you do it might short something.
Old 07-25-2008, 11:57 PM
back to business
No idea, sorry!!! Might want to look into a custom burned chip though
Edge
Very odd! I have an 03 6.0L 4x4 and the performance was just the opposite for me. I have been happy with it. Mine is just the module, no attitude and only 3 settings, 50, 75, and 100hp gains. My mileage stayed the same at 13mpg.
Is yours a module like mine that mounts under the hood. I don't think it is even possible but did you plug in the wrong harness. You pull the middle harness of the three from the pcm and plug it into the module's empty slot, then the edge pcm harness goes in the middle where the stock used to be. It should be that simple. Like I said, I don't have the attitude so that is all I can offer other than giving you their phone #.
(801)476-3343. I know they will gladly take it and have it back within a week. They will actually hook it up to that vehicle and test how it runs. They will also go through the whole board and make sure all is up to specs. I know everyone has their own opinion on what performance chip is the best so I am sure you will have people slam it on this forum so be prepared for that. I hope you get it figured out.
I'm about to slam those sulastic rubber springs I just mounted while I'm on the subject of slamming. It was a major pain to install them with just jacks and stands in the drive, especially if you have big hands. I believe I have to agree with a fellow that posted his comments about them in the suspension forum. "I literally had to strain to notice a difference if there was one at all". I bought them because I had a 2 level back fusion and heard they smooth and take the harshness out of the 3/4 ton ride. My back can literally notice a 2 lb difference in my tire pressure, but not these. If I didn't put them on myself, I wouldn't have known anything had been done to the suspension, no kidding.
As much of a hassle as it was on my back to mount them, I will most likely keep them on just to avoid all the BS I went through mounting them. I may just eat the $340. As for all of the benefits they claim like shorter brake distance, better handling, reduction in vibration, etc...I noticed none of those things.
So in my opinion, they did nothing for me, I may just take them off anyway and send them back to get a better riding shock all the way around as that will cost about the same and that WOULD make a noticeable difference. I am sure the Ranchos that came with the FX4 package are not the greatest.
Old 07-26-2008, 12:03 AM
Thanks for reply flyin, Ya everything on the juice is y harness,map,mat,icp,tps,cps i have checked all of them several times making sure no bent pins or bad connections.when the key is turned on the display powers up and i start it but it goes right into a up down idle search with almost no response to pedal position.
Old 07-26-2008, 12:08 AM
07OUTLAW, ya i know what you mean about a chip.i figured i didnt want to go crazy for a tune but i guess this is what i get LOL. So the wildman is the way to go for the 7.3?
Thumbs up psd
did you put the truck in limp mode
Old 07-26-2008, 12:10 AM
Thumbs up psd
did you put the truck in limp mode.when you unpluged it how did she run
Old 07-26-2008, 12:11 AM
I wouldnt even call it limp mode,it would not have even made it out my driveway. hoped it didnt fry any factory equipment so i put it back to stock and fired right up and ran normal.
