no brakes or steering - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-24-2008, 03:14 PM Thread Starter
i have a 2000 f350 crewcab longbed and i i went to walmart today and the truck drove fine i got out of walmart started the truck up went to put it in drive and it drove right threw the brakes at idle. i got out of the truck and there was about a quart or two laying under the drivers side. checked all the fluids engine, trans, and brakes were all fine. powersteering was low. so i started the truck back up it kept leaking and i went to try and steer and had no power steering. i searched on here and a couple of other people have had the same problem but i don't understand what would effect the brakes? i am thinking it is either the power steering pump or one of the lines.
mjurecki is offline
post #2 of 9 Old 07-24-2008, 03:17 PM
duct tape & zip ties
bigcountrysg's Avatar
The powersteering pump supplies pressure for the brake booster. So if your leaking powersteering fluid and your brakes are not working. I would be checking the line from the brake booster to the power steering pump.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 9 Old 07-24-2008, 03:19 PM
460+'s Avatar
I second that.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #4 of 9 Old 07-24-2008, 03:24 PM Thread Starter
my trucks about 15-20min away and i have to wait till tonight to get a ride over there is that hose hard to see or replace.
mjurecki is offline
post #5 of 9 Old 07-24-2008, 03:29 PM
I don't know I never dealt with it. I have replaced the powersteering pump on my truck. That took me about 2 hours.
2002 7.3L burnt
post #6 of 9 Old 07-24-2008, 03:43 PM
Desert Shield/Storm Vet
vitalidle's Avatar
I just went through the same issue with no brakes as BC is correct the ps pump supplies the pressure for the brakes called hydroboost as a diesel doesn't create vacuum for the master cylinder
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #7 of 9 Old 07-24-2008, 03:55 PM Thread Starter
how long did it take you to replace that line
mjurecki is offline
post #8 of 9 Old 07-24-2008, 04:07 PM
vitalidle's Avatar
I didn't I had the dealer replace my ps pump. Sorry I was just confirming the reason you don't have brakes. Can't help ya with the ps line
Auto 93,000 miles
DP Tuner F5
post #9 of 9 Old 07-25-2008, 10:28 PM
Send a message via AIM to blizzardwarrior7
Well you have to find the leak first....Put some more power steering fluid in their and try to see where its leaking. It might just be a matter of the hose going to the P.S. fluid reservoir needing to be pushed on. The hose is easy to get to also, just look right near where you pour the p.s. fluid.
blizzardwarrior7 is offline
